Autor Thema:  1/35 T-28 Super Heavy Tank von Dragon  (Gelesen 3488 mal)
vonMackensen1914
« am: 14. November 2012, 09:31:08 »
Material: Plastik
Jahr: 2012
Preis: ca. 60 €
Hersteller: Dragon
Teile: ca 700
Greeble Qualität: Topp  8)
Hier noch Infos zum Original:
T28 Super Heavy Tank
From Wikipedia, the free encyclopedia
Jump to: navigation, search
For other uses, see T28 (disambiguation) or T95 (disambiguation)
T28/T95 GMC
Type   Super-heavy tank
Place of origin   United States
Production history
Manufacturer   Pacific Car and Foundry
Number built   2
Specifications
Weight   95 short tons (86.2 metric tons)
Length   36 ft 6 in (11.1 m)
Width   14 ft 11 in (4.39 m)
Height   9 ft 4 in (2.84 m)
Crew   4[1][2]
________________________________________
Caliber
105 mm
Elevation
19.5° to -5°
Traverse   10° right, 11° left
Maximum range   12 mi (19 km)
Armor
12 in (300 mm)
Main
armament   105 mm T5E1 gun, with 62 rounds
Secondary
armament   .50-cal machine gun, with 660 rounds
Engine   Ford GAF V-8 gasoline
500 hp (372 kW)[1]
Power/weight   5.8 hp/tonne
Suspension   double track
Operational
range   100 mi (160 km)
Speed   8 mph (13 km/h)[2]
The T28 super heavy tank (also called 105 mm Gun Motor Carriage T95) was a prototype heavily armored self-propelled gun designed for the United States Army during World War II. It was originally designed to be used to break through German defenses at the Siegfried Line, and was later considered as a possible participant in an invasion of the Japanese mainland. Sometimes referred to as a super-heavy tank, the T28 was re-designated as the 105 mm Gun Motor Carriage T95 in 1945 and then renamed a super heavy tank in 1946.[3]
Development
The T28/T95 was designed as a counter to the German heavy tanks,[2] such as the Maus[4] It was also set to be used for attacking the heavy defences expected of the German Siegfried Line.[3]
It was first conceived in the spring of 1945, but proved to be too late to be used in World War II. The original name for the project was to be T28/T95. The Pacific Car and Foundry Company designed it for the final push in Europe, but by the time the first tank was completed and ready for combat, the war was over.[1] The original plans called for five prototype vehicles to be built, and eventually for a total of twenty-five tanks to be constructed.[3]
As it did not have a turret, but a fixed casemate mount instead for its main armament, the T28/T95 more closely resembled a self-propelled gun, and was redesignated as the T95 Gun Motor Carriage in 1945, but in June 1946, the vehicle was redesignated again as Super Heavy Tank T28.[3] It has been argued that it was neither a super-heavy tank nor a self-propelled gun, but that it was in fact a very heavy tank destroyer, more accurately as an American version of one of the German Jagdpanzer-style tank destroyers, intended to take on German heavy tanks.[2]
Two prototypes of the T28 were built. They underwent evaluation at the Aberdeen Proving Grounds and the Fort Knox facilities until 1947. In 1947 one of the T28s was heavily damaged by an engine fire during trials at Yuma Proving Grounds and scrapped, and the other T28 was reported broken up and also sold for scrap. The T28 never went into service. This was because during the later stages of T28 development and evaluation were overtaken by that of the T29 and T30 turreted heavy tank design.[3] The T29 mounted the same gun as the T28 in a conventional rotating turret. The T30 was developed with a larger-caliber gun and more powerful engine. Due to this the T28 program was terminated in October 1947.[3]
[edit] Surviving vehicle
In 1974 the last prototype was discovered abandoned in a back field at Fort Belvoir, Virginia. It is unknown where it spent the intervening 27 years. It is the sole remaining example of these tanks and was exhibited at the Patton Museum of Cavalry and Armor in Kentucky.[1][5] It is currently being prepared for shipment to its new home at Fort Benning, Georgia.
Design
Front three-quarter view of the T28 at the Patton Museum
Side view
The T28 was designed and manufactured by Pacific Car and Foundry.[3] The mechanical superstructure was taken from a T23.[2] The original plan was to build five prototype vehicles, with a production total of 25. Its total weight when fully equipped would have reached 95 short tons (86 tonnes).[1] To carry this weight, it used four tracks instead of two, each 12.9 inches (328 mm) wide.[3] The outer tracks could be detached for easier transport.[1] After removal they could be fixed together to make a unit that could be towed behind the tank. Due to its extreme weight and low engine power, the T28 had extremely limited obstacle-crossing ability and could not cross any of the portable bridges available at the time, and so was considered impractical in the field and not suitable for production.
The T28 had no conventional turret, with a casemate style hull instead, giving it a comparatively low profile. Its main armament was a 105 mm T5E1 gun, in a ball-shaped gun mantlet set into the hull front.[1] Although it was technically a part of a gun mantlet it was really attached to the hull.[2] Due to this it was not a true tank at all, but a "Gun Motor Carriage".[2] The traverse was limited to 10° right and 11° left, and elevation from 19.5° to −5°. When traveling, the gun was locked at the maximum elevation.[3] It also had a .50 inch (12.7 mm) M2 Browning machine gun mounted above the commander's hatch.[1] The main gun had a muzzle velocity of 3,700 feet per second (1,130 m/s), with a range of up to 12 miles (19 km).[1]
The armor was very thick compared to other tanks of the time, up to 12 inches (300 mm) thick on the front. This was considered heavy enough to provide protection from the German 88mm gun used as tank gun and anti-tank guns.[3] The lower hull front had 5.25 in (130 mm) of armor, and the sides 2.5 in (64 mm). The suspension system and lower hull were covered with 4-in (100 mm) thick steel skirts.[3] The engine was a gasoline-powered Ford GAF V-8, delivering 500 hp,[1] which left the vehicle underpowered with a top speed of about 8 mph (13 km/h) and greatly limited its obstacle-climbing capability.[3]
Comparisons
The Tank, Heavy Assault, Tortoise (A39) was a British super-heavy assault gun developed for the same purpose as the T28. Six (of the 25 planned) of these 79-ton giants with 96 mm guns were built at the end of World War II.
Comparison to the parallel US developments
Specifications[1][3]
Specifications   T28   T29   T30
Weight   86.2 metric tons   64 metric tons   65.8 metric tons
Crew   4 men   6 men   6 men
Engine   Ford GAF V-8 / 500 hp (373 kW)   Ford GAC four cycle 60 degree V12 / 650 hp (485 kW)   Continental AV1790-3 / 704 hp (525 kW)
Speed   13 km/h   32 km/h   26.5 km/h
Maximum armor thickness   305 mm   279 mm   280 mm
Length   11.10 m   11.57 m   11.57 m
Width   4.39 m   3.80 m   3.80 m
Height   2.84 m   3.20 m   3.20 m
Armament   105 mm T5E1 gun   105 mm gun T5E2   T7 155 mm gun
Secondary armament   .50 Caliber Machine Gun   •   2 × .50 (12.7mm) Browning M2HB machineguns;
•   1 × .50 M2HB flexible AA;
•   1 × .30 Browning M1919A4   7.62 mm machine gun
Ammunition   62 rounds   63 rounds   34 rounds
Comparison with other countries' designs
   T28   A39 Tortoise
Weight   86.2 metric tons   79.2 metric tons
Crew   4 men   7 (commander, driver, gunner, two loaders, two machine gunners)
Engine   Ford GAF V-8 / 500 hp (373 kW)   Rolls-Royce Meteor V12 / 600 hp (447 kW)
Speed   13 kilometers per hour   19 km/h
Armor   305 mm   178 – 228 mm
Length   11.10 meters   10.0 m
Width   4.39 meters   3.90 m
Height   2.84 meters   3.00 m
Armament   105 mm T5E1 gun   96 mm Ordnance QF 32 pounder
Secondary armament   .50 caliber Machine Gun   3 × 7.92 mm Besa machine guns
Ammunition   62 rounds   60 rounds
Quelle: http://en.wikipedia.org/wiki/T28_Super_Heavy_Tank
Und ein Video mit dem Fahrenden Prototypen:
Und die Bilder der Teile, Sie sind allerdings nicht ausgepackt, sind zu viele Spritzlinge.  :pffft:
Eine menge Zurzeit im Bau.
mk
Re: 1/35 T-28 Super Heavy Tank von Dragon
« Antwort #1 am: 14. November 2012, 22:42:00 »
schöner und spannender Bausatz. Unglücklicher Weiser ist das Fahrzeug zu breit mit 141mm, statt 130,2mm. Grund ist, dass das Fahrwerk hier vom Sherman übernommen wurde, dass des T-28 jedoch schmaler war!!!! :( http://www.missing-lynx.com/reviews/usa/dml6750reviewcs_1.html
Sollte dennoch keinen davon abhalten, dieses schöne Ungetüm zu bauen, werde mir nach dem Tortoise auch diese Anschaffung gönnen...:)
1:350 IJN Nagato + Fotoätz (Hasegawa)                                       Verschifft
1:700 HMS Queen Elizabeth 1918 (WEM)                                                        50%
1:350 HMS Hood (Trumpeter + Lion Roar), Bauzustand 1937-39                    50%
1:35 M1A1 Abrams AIM (Dragon) + MinePlow (Tamiya)                                     100%
1:35 Centurion MK 3 KoreaWar (AFV + MK III Turrte von LionMarcModeldesign + Scratch)
McFrag0815
  • André Middeldorf
    • http://www.tinwarriors.de
« Antwort #2 am: 15. November 2012, 00:15:07 »
Die falschen Ketten zu nutzen und damit die Maße des Fahrzeugs zu verhauen ist doch mal wieder ein ganz typischer Dragon-Klopper  :pffft:
Aktuell auf dem Tisch:
Teile für ein F-16C Cockpit in 1/1
jackrabbit
« Antwort #3 am: 15. November 2012, 09:35:17 »
ja, aber ich denke, dass DRAGON dies schon gewusst hat und es bewusst in Kauf genommen hat.  8o
Die meisten Käufer wissen und bemerken es nicht, also halt "Beschiss" am Modellbauer zwecks Geldmacherei.   X(
Grüsse
